It is currently Sat Sep 13, 2025 7:01 pm
 Post subject: Making A Radius Dish
PostPosted: Wed Jul 23, 2008 9:09 pm
http://youtube.com/watch?v=tvGemvizrz4
 Post subject: Re: Making A Radius Dish
PostPosted: Mon Sep 01, 2008 10:11 am
First name: Chuck
Last Name: Hutchison
City: Houston
Man, that's a cool idea. Wonder if you could use an electric motor instead of your router? Love the casters idea to help keeping it straight.
PostPosted: Sat Sep 06, 2008 3:34 pm
I don't see why not. If I build one into my work bench I was going to use a slow rpm. motor with a drive roller McMaster Carr. You would need to make a motor bracket with a spring tension adjustment something like on a contractors table saw. I also planned on putting the drive roller in one of the corners instead of one of the casters. I think it would make for a clean look and remove one less caster. I'd also step up the casters to have bearings.
PostPosted: Sun Sep 14, 2008 5:42 pm
Last Name: Livermore
State: Minnesota
Chris,
Great idea. Wonderful tutorial.
I'm working on building one of these right now.
This link to help anyone doing the with the math.
http://www.1728.com/circsect.htm
Really the circle calculator has helped me for a couple years in figuring all kinds of cool stuff related to the various radii on the guitar.
PostPosted: Sun Sep 14, 2008 8:05 pm
Thanks for adding the link here Dave. That will help. Here also is a spread sheet that Massimiliano Monterosso made up.
http://www.maxmonte.com/utilities/radiusing.xls
PostPosted: Thu Apr 23, 2009 11:56 am
What do you use for the abrasive? What rind of sand paper will conform to the convex geometry?
PostPosted: Thu Apr 23, 2009 12:36 pm
You can glue on strips across the dish or buy 24" sanding disc that are used for sanding wood floors or get them from Blues creek guitars. The radius of the dome isn't that small to affect the paper as it conforms with no problem.
